Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Cannot create a Product Design Suite Ultimate 2013 deployment package.
2 REPLIES 2
AdamsKR
714 Views, 2 Replies
I'm trying to create a standalone deployment package for Ultimate 2013 and I get an error while the package is being made. The error tells me that the following problems prevent the deployment configuration from completing: The copy functions cannot be used.
I'm saving the deployment on a server and creating the package from a Windows 7 x64 PC with full rights to the server folder. I've seen post that say to use a Windows XP 32 bit machine to make the deployment but I don't have any Windows XP computers.
2 REPLIES 2
AllenJessup
in reply to: AdamsKR
If you don't get any results here. Try the Installation & Licensing group. It's monitored by Autodesk so they can possibly answer it.
Allen Jessup
Allen Jessup
CAD Manager - Designer
TravisNave
I've seen anti-virus and UAC block the copying (especially .exe) to different locations.  Make sure your share is full control to the everyone account and the file and folder permissions also have the same.  When you make your share, you'll want to use \\servername\share rather than place it a few more folders down or you will run into folder depth/character limits.  You can keep the same physical pathing on the server per whatever standards you are using (i.e. ISO-9000) but simply share the last folder.  Probably need to turn off real-time protection on both ends, or at least make an exception. If you are using media, copy it first to the HDD.
Continued here.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
