Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
.bat files with Win2K
15 REPLIES 15
Message 1 of 16
483 Views, 15 Replies
We have just upgraded to windows 2000 from windows 98. We have several
batch files (*.bat) that we use to copy drawing files and create job
folders, now none of them work. Has anyone experienced this and any
suggestions to correct?
Ted Evans
CAD Manager
Architecture & Engineering Services
RadioShack Corporation
817-415-2034
15 REPLIES 15
Message 2 of 16
there are some dos commands which are no longer supported, and some great
enhancements and new commands available. check w2k help 'command reference'
and see what's up. there's aslo a batch command newsgroup
alt.msdos.batch.nt at microsoft.
Jamie Duncan
"Maybe the Hokey Pokey is REALLY what's it all about"
"Ted Evans" wrote in message
news:75742928EFDA8D03FD7082F95C74DF1E@in.WebX.maYIadrTaRb...
> Ted Evans
> CAD Manager
> 817-415-2034
Message 3 of 16
Email me a copy of the bat file and I'll see if it can be altered to work in
W2K
Robert
> Ted Evans
> CAD Manager
> 817-415-2034
Message 4 of 16
Rename the file to have a ".cmd" extension.
Matt
mstachoni@comcast.net
mstachoni@bhhtait.com
On Wed, 19 Feb 2003 11:46:11 -0800, "Ted Evans"
Message 5 of 16
what will that do Matt? Is there an advantage calling it a cmd file?
(just curious)
Jamie Duncan
"Matt Stachoni" wrote in message
news:vuv75v42u4ou0s4aielvu5i9og10ckuia2@4ax.com...
> Matt
Message 6 of 16
On Wed, 19 Feb 2003 14:14:53 -0800, "Jamie Duncan"
>(just curious)
I have no idea. But I thought it would be pretty cool if it worked.
Matt
Message 7 of 16
HA! Matt, you've destroyed my image of you as the all knowing computer
supreme jedi master.
Brian K. Harder, AIA
CAD Manager - RNL Design
http://www.rnldesign.com
Remove .ns to email
news:32a85vo8o1t8ci33ccg3k0r9kuldshn284@4ax.com...
> >(just curious)
> Matt
Message 8 of 16
The only problems I had was Syntax related--- placing file names in quotes,
etc.
All my stuff works with slight modifications.
> Ted Evans
> CAD Manager
> 817-415-2034
Message 9 of 16
Can you expand on this a little more. What types of "slight modifications"
did you have to make? These are essential for our day to day operation, I
will have to come up with some other method of performing the task these
batch file do if I can not get this resolved.
Ted Evans
CAD Manager
817-415-2034
"Peter Friedrich" wrote in message
news:34881480179D6EAF52C03F5D886467FE@in.WebX.maYIadrTaRb...
quotes,
> etc.
> > Ted Evans
> > CAD Manager
> > 817-415-2034
Message 10 of 16
cmd is to be preffered since it uses cmd.exe that is Windows NT's shell and
bat uses command.com that is the DOS shell.
Jimmy
www.jtbworld.com
"Matt Stachoni" skrev i meddelandet
> >(just curious)
> Matt
Message 11 of 16
Hey Ted - why not post 'em in cusfiles so we can have at em
Jamie Duncan
news:DDFFE4AA9A793E880F652895B470743E@in.WebX.maYIadrTaRb...
> Ted Evans
> CAD Manager
> 817-415-2034
> quotes,
> > etc.
several
> > > Ted Evans
> > > CAD Manager
> > > 817-415-2034
Message 12 of 16
I have posted two of the batch files and the shortcut incase there is a
problem with the .pif file to the customer-files newsgroup.
Thanks for your help.
"Jamie Duncan" wrote in message
news:F849C52DB0BB806740123D66DA740A87@in.WebX.maYIadrTaRb...
> Jamie Duncan
modifications"
I
> > Ted Evans
> > CAD Manager
> > 817-415-2034
> > quotes,
> > > etc.
> several
> > > > Ted Evans
> > > > CAD Manager
> > > > 817-415-2034
Message 13 of 16
On Thu, 20 Feb 2003 14:38:13 -0800, "Jimmy B"
Sorry, but this is not true.
Command.com is a 16-bit command processor, available in Windows NT+
strictly for compatibility with older programs.
Both bat and cmd files use the cmd.exe command processor, as dictated
by the COMSPEC environment variable. However, command.com only
recognized bat as a valid extension and will not run cmd files.
Matt
Message 14 of 16
I haven't done batch files to such depth... looks OK (as far as I understand
it in DOS)
Suggestions:
Have you tried simplifying it...
remove Colors (sorry, I love colors, too) and other escape-character
dependent coding (for now).
Add "quotes" to any hard-coded file/path names
also:
if not exist %store%ME1.DWG ren XXXXME1.dwg %store%ME1.DWG
does %store% = %STORE% ? (setenv was named %STORE%)
As for what I changed... was a while back... simple syntax that I can't
recall now.
I found one old website during that era:
http://home7.inet.tele.dk/batfiles/main/tricktip.htm#top
-- has DOS instructions... was useful for me once, but still, it's NOT
Windows.
Hope that helps... will be looking for more info, too.
> Ted Evans
> CAD Manager
> 817-415-2034
> quotes,
> > etc.
several
> > > Ted Evans
> > > CAD Manager
> > > 817-415-2034
Message 15 of 16
Hey Ted - I looked through them - and I was wondering if maybe there is
another way
Like the one that creates the project folders - why not just hav a dummy
folder set up with all of the subfolders properly named etc. The just copy
and paste the folder and rename the root with your project name/number?
I'm wondering if some of the others could be done using windows functions as
well?
Jamie
news:4D33851940B3EF1B50D1628FCB34CDCA@in.WebX.maYIadrTaRb...
> > Jamie Duncan
> modifications"
operation,
> I
these
> > > Ted Evans
> > > CAD Manager
> > > 817-415-2034
> > > quotes,
> > > > etc.
> > several
job
any
> > > > > Ted Evans
> > > > > CAD Manager
> > > > > 817-415-2034
Message 16 of 16
Sorry about that. I must have remembered wrong since I've thought I run into
some situation a while ago that I run into cmd working better than bat and
when I checked the process the bat file used command.com but now when I
checked this was not the case.
/Jimmy
news:63ic5vkfv5hcr9i661fjtb3qosf6dmhp1q@4ax.com...
and
> Matt
Administrator Productivity
