Corey,
>I use this @Home for backup.Is there a way to configure it so a scheduled
>backup job will run the next time the computer is powered up, if it was down
>at the time the backup was set to begin?
As far as automating the backup in case it was missed due to a
power-off situation, I don't think there's nothing built in to the
application to do this. You would have to build this yourself.
One mechanism I can think of off hand is to use Scheduled Tasks to run
a batch file that fires off the backup process using preconfigured
backup sets. This is documented here:
http://www.jsifaq.com/sube/tip2200/rh2265.htm
I use a variant of this to run my backups automatically.
By using a batch file fired from Scheduled Tasks, you can do some
other peripheral things like check to see if the last backup worked.
For example, to set the initial status of your backup, have the batch
file set an environment variable called "BackupStatus[date]" to
"False". The link above directs you how to create a string of the
current date in the batch file, so you can use that parameter as part
of the env. variable name. Then at the end of the backup process
simply set the "BackupStatus[Date]" environment variable to "True."
Then, in your Startup folder create a batch file that checks the
status of the BackupStatus[Date-1] environment variable. If the power
was out when the backup started, there won't be a value. If the power
fails while the backup was happeining, it will be False.
Therefore, if the variable is anything but True, you know you didn't
get a true backup of the night before, so it can fire off the backup
batch file again.
Of course, this is totally off the top of my head so I don't know if
it really would work, but I think you get the idea.
Matt
mstachoni@comcast.net
mstachoni@bhhtait.com
On Fri, 19 Sep 2003 06:03:55 -0700, "Corey A. Layton"
wrote:
>"Matt Stachoni" wrote in message:
>> Windows 2000 and XP's 'NTBackup" utility is excellent, because it's
>> (a) schedulable and automated and (b) free.
>Matt,
>Not so much of a concern for my Daily Incrementals, but if it misses the
>Weekly Normal, that's trouble...
