Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
backup and restore multiple profiles
2 REPLIES 2
TherealJD
796 Views, 2 Replies
I am familiar with exporting individual profiles to *.arg files. But i was wondering if there was a method to backup multiple profiles from an AutoCAD (or its verticals) installation, and restore multiple profiles too?
Working with AutoCAD 2008/2009/2011 and its verticals on WinXP and Win 7 OS
2 REPLIES 2
dgorsman
in reply to: TherealJD
You could export the profile contents under the HKCU registry path.  Its virtually identical to the ARG file contents.  When they are needed back you can merge the REG files back in as long as permissions are set accordingly.
TherealJD
in reply to: dgorsman
Thanks, i think i found the keys i need to backup from the registry. I'm working on a batch file to run and export those keyes to a reg file..
This is what's in my bat file:
echo Profile support files copied.
echo will copy registry. When prompted enter your login password to complete export.
pause
REGEDIT /E c:\temp\cad_2011.reg "HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.1"
FYI
i had to make the regedit export to a local drive. it didn't work exporting direct to a network drive.
Administrator Productivity
