Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Autodesk Iventory Advisor - Installation type info
5 REPLIES 5
1674 Views, 5 Replies
Hi, I m using Autodesk Inventory Advisor tool to get the numbers of license already used on my LAN, and that's work great, but I want to get the installation type too, and this field only shows some numbers, 0,1 and 3, I'm looking  for some information about this, what does it means each number? Please if someone knows something about it, reply me, or maybe some post or manual to get more info about the tool.
Thanks and Regards
5 REPLIES 5
TravisNave
I would suspect they refer to stand-alone, network, or multi-seat stand-alone.
Autodesk Forums:
Hi, and thanks for your reply Travis. I found this info from a older post, but i'm not sure if it's apply for this tool also:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17847202&linkID=9242018
It's say the following:
1 – Network
2 – Standalone
3 – Multiseat Standalone
But i have as result differents numbers: 0,1 and 3
TravisNave
It wouldn't surprise me if it was basically the same thing.
Autodesk Forums:
Right, I just wish  to validate these values, I consider is a important thing which should be include on the manual, cause the goal for the tool is to get autodesk licenses including installations type
TravisNave
Right. I mean, the tool clearly states that it lists license type. And in all reality there can only be 4 different types. Stand-alone, network, multi-seat stand-alone, and trial. I am sure those numbers translate to that. I am surprised there is no key in the guide or help system.
Autodesk Forums:
Administrator Productivity
