Allen Jessup
CAD Manager - Designer
Allen Jessup
Allen Jessup
Layer manger crash can be solved one way.
Simply type one command and done.
MAPSKINMAP
This command keeps metallic skin off so heavy resources are not needed.
We have witnessed two basic layer manager errors:
The layer manager won't populate that forces the user to close and reopen the layer manager palette. This causes a dialog box to pop up but can be cleared out by clicking 'ok' a couple of time.
The .net error that throws a pop up that won't go away has typically been caused by creating a layer from the command line or lisp routine while the layer manager is open and then trying to undo back to a point before the layer was created. This dialog box looks different than the one in the OP's post.
As long as AutoCAD doesn't crash out and completely close out you may still have an opportunity to save your file instead of forcing AutoCAD to close through the task manager. If the pop up constantly repeats itself when you interact with it, you should be able to Alt+F4 AutoCAD. It does take a fair amount of timing but AutoCAD won't shutdown using Alt+F4 without asking you if you want to save each one of your open files. Once the timing is right you should be able to stop on the standard save dialog box - at this point it is up to you to decide if you want to save the file the problem occurred in.
The .net error is likely localized to the current file so you should be able to cancel out of the save dialog on the next file (if you had multiple files open). Using Alt+F4 is the same as using the 'exit' command ... you can cancel at anytime and stop the closing process.
