I've installed Civil3D and am having some problems with the icons for the ribbons not showing up when I copy the menu from the default install location on the C: drive to the network. Once I do that and call up the menu from it's new location, everything works fine. But if I simply "rename" that same menu in it's new location and call it up, some of the icons don't show up.
I haven't altered the menu in any way, or pathed anything differently. Just simply renamed it.
And one other issue is:
Does anyone know how to change the icons on the bottom of the screen to show them in "TEXT" description, instead of the symbol icon? You used to be able to right click on any of them and click off the "Use Icons" setting. That doesn't seem to be there now.
I've attached a PDF with screen shots of everything I'm talking about.
Thx!
Check that all your icons are stored in the same directory. This often happens if an icon is modified & stored away from the usual directory
Yes. The answer is you can't.
Autodesk decided to remove that option for us.
Complain about it here and maybe we can get it back in 2016.
I have not tested this, but I *think* the DLL file has to be named the same as the CUIX file.
IOW, copy %appdata%\Autodesk\C3D 2015\enu\Support\C3D.dll to C3DSentio.DLL and give that a try.
