Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Autocad Educational Version
9 REPLIES 9
Message 1 of 10
riznasp
1395 Views, 9 Replies
Dear All,
We just realized that most of our file are converted to Autocad Educational Version. As 90% of the technical guys use 2014 with SP1 and what i came to know that 2014 version will not give you the warning message when we try to open it. So we work on a file without realizing that its an Educational Version file and at it spreads out to all the other files in the projects when we copy something. We use only commercial version in our office.
Do you guys have any suggestions to fix all this files as a batch. Because of i have hundreds of files affected with the same problem.
Thanks & Regards
Riznas
9 REPLIES 9
Message 2 of 10
riznasp
in reply to: riznasp
Guys,
Dont you have any idea about a solution for my problem?
Riznas
Message 3 of 10
abubakars
Can you upload here a sample drawing which has the issue?.
Message 4 of 10
I have heard people say in the past, that you can contact your Autodesk Authorized Reseller, and they can batch fix these files for you.
Melanie Stone
Facilities Data Management
IWMS / CAFM / CMMS / AutoCAD / Archibus / Tririga / Planon / MRI Manhattan CenterStone / Revit / data normalization, data mapping, reporting and process documentation
mistressofthedorkness.blogspot.com/
Message 5 of 10
pendean
I think most of us are wondering why you didn't just Google Search the solution that's not been a secret for a decade 😉
Message 6 of 10
rkmcswain
If the drawings are staying internal, get everyone up to 2014 SP1 and the plot stamp will not appear, as confirmed by an Autodesk employee, here.
R.K. McSwain     | CADpanacea | on twitter
Message 7 of 10
I contacted the autodesk authorised centre. But instead of giving a solution they were directing me to autodesk webpage where it says samething what you all are saying and i knew that all before.
Riznas
Message 8 of 10
riznasp
in reply to: pendean
I had gone through all sort of search but i couldn't find a solution to do it as a batch anywhere. I know how to convert the files by using dxfout/in command. But the problem comes when we have hundreds of files.
Riznas
Message 9 of 10
abubakars
Riznas,
If you do not have 2014 with sp1 then try with BatchInEditor or BatchInDatabase to first export your files into DXF then using DXF2DWG convert them back to DWG, I know it is not a straight forward solution but will help you to get want you wanted.
The tools are available to download from Autodesk Exchange Apps.
Message 10 of 10
riznasp
in reply to: abubakars
Thats Great. This is something i'm looking for.
Thanks a lot.
Riznas
Administrator Productivity
