Dear All,
We just realized that most of our file are converted to Autocad Educational Version. As 90% of the technical guys use 2014 with SP1 and what i came to know that 2014 version will not give you the warning message when we try to open it. So we work on a file without realizing that its an Educational Version file and at it spreads out to all the other files in the projects when we copy something. We use only commercial version in our office.
Do you guys have any suggestions to fix all this files as a batch. Because of i have hundreds of files affected with the same problem.
Thanks & Regards
Riznas
Solved by abubakars. Go to Solution.
If the drawings are staying internal, get everyone up to 2014 SP1 and the plot stamp will not appear, as confirmed by an Autodesk employee, here.
I contacted the autodesk authorised centre. But instead of giving a solution they were directing me to autodesk webpage where it says samething what you all are saying and i knew that all before.
Riznas
I had gone through all sort of search but i couldn't find a solution to do it as a batch anywhere. I know how to convert the files by using dxfout/in command. But the problem comes when we have hundreds of files.
Riznas
Riznas,
If you do not have 2014 with sp1 then try with BatchInEditor or BatchInDatabase to first export your files into DXF then using DXF2DWG convert them back to DWG, I know it is not a straight forward solution but will help you to get want you wanted.
The tools are available to download from Autodesk Exchange Apps.
