Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
marksmith17349
746 Views, 3 Replies
Attaching Xref
When we attach an exref we have to set the layer first, (XREF) and then attach the file we want.
I'm looking for a way to simplfy the process by combining the two tasks.
For one, it seems I'm not on the "right" layer when I attach an xref often.
I was thinking of a custom icon perhaps on a toolbar that when launched would first set the layer to XREF and then proceed to attaching the XREF
Appreciate you help.
Mark
3 REPLIES 3
skintsubby
in reply to: marksmith17349
Try adding the follow macro to an icon
^C^C_-layer;m;xref;c;white;xref;^C^C_-xref;a;
It will create layer "Xref" and give it the colour white, then open your xref manager.
Mark
Thank you for your reply.
I'm wondering what will happen if the file I attempt to attach an Xref with that command line if it already has a layer xref?
Mark
pendean
The macro above uses -LAYER command's MAKE sub-option: look it up in HELP, it works without worries about if the layer is already in the file or not.
Administrator Productivity
