When we attach an exref we have to set the layer first, (XREF) and then attach the file we want.
I'm looking for a way to simplfy the process by combining the two tasks.
For one, it seems I'm not on the "right" layer when I attach an xref often.
I was thinking of a custom icon perhaps on a toolbar that when launched would first set the layer to XREF and then proceed to attaching the XREF
Appreciate you help.
Mark
Solved by pendean. Go to Solution.
Solved by skintsubby. Go to Solution.
Try adding the follow macro to an icon
^C^C_-layer;m;xref;c;white;xref;^C^C_-xref;a;
It will create layer "Xref" and give it the colour white, then open your xref manager.
Mark
Thank you for your reply.
I'm wondering what will happen if the file I attempt to attach an Xref with that command line if it already has a layer xref?
Mark
The macro above uses -LAYER command's MAKE sub-option: look it up in HELP, it works without worries about if the layer is already in the file or not.
