Hi Clinton,
My Tungsten E2 PDA has excellent battery life. Unfortunately, the Palm OS
isn't as widely supported and I cracked the screen, by foolishly sticking a
blot and my PDA in my jeans front left pocket. Ouch. Now the cost to replace
it or repair are so similar, I've been waiting to upgrade my cell phone to
something that runs a Pocket Windows version.
Actually, it would be great if somebody created an iphone interface program,
although typing in the iphone is a kind of pain, and you can't use a stylus.
One has to use one's fat finger, even the little finger feels fat, that's
how close the on screen keys are.
Using vehicle power is something I've done. In fact, I remember years ago
working on a project near downtown LA around 1986. It rained for what felt
like two weeks straight, while the time was ticking for a rush project. I
ended up using plastic lead on mylar for the field notes. It works
beautifully, since no ink or lead will run. You can even write underwater.
God, it was cold that Winter, by LA standards, in the low 40's. 😉
Regards from Los Angeles,
Emmanuel
"clintonG" wrote in message
news:5804931@discussion.autodesk.com...
Windows Mobile, Windows CE, and Windows Embedded are the marketing terms you
can use to search the web for the latest devices that support the optimal
device OS the OEMs are using for their devices to run what are often
proprietary software applications. The device markets are growing
exponentially resulting in many new or improved devices that can be used for
as-built documentation. Wireless power however continues to be a limiting
factor.
On these newer devices the size of the display can be a determining factor.
You'll observe the user interface is being transitioned to touch-screen
interfaces.
Carrying multiple batteries for the smaller form factors is a lot easier
than those for laptop form factors. And don't forget to carry power cords
anyway. I was in a situation just last night that a spare power cord came to
the rescue.
As an aside, do you think it would be reasonable to use a vehicle as a power
generating source when on a site that has been abandoned or has no power?
There's a lot of wasted energy or potential energy going unused that sits
parked. I remember jobs I was on during the winter that I left the truck
running just so I could jump in every so often to warm up.
<%= Clinton Gallagher
NET csgallagher AT metromilwaukee.com
URL http://clintongallagher.metromilwaukee.com/
"Emmanuel Garcia" wrote in message
news:5804774@discussion.autodesk.com...
How are you handling as-built measurements? I noticed Hilti came up with a
sub $200 laser measuring device, accurate to within 1/16" or so. Some
similar models, going up in price by a few hundred dollars, include
Bluetooth connectivity. Anybody using those? If so, what kind of software
are you using?
Likewise, I've noticed that GPS based systems keep getting better and
cheaper. Some units can achieve much higher resolutions, in the centimeters
/ sub-meter range, using both GPS and a radio/signal emitter unit. What are
the prices for these and what has your experience been like with them?
I often need to produce as-builts for property management and remodel
purposes. The accuracy I like to track is about 1/4", and I don't like
errors to be greater than 1" in about 100'. However, for a new type of
project I have been working on, called Cost Segregation, it appears as if
the accuracy can drop to within 1 foot in 100 foot, hence GPS based systems
begin to make more sense. I am planning to measure the building perimeters
pretty tightly, using laser devices, and the interior stuff possibly using a
GPS. What is your take, and words of wisdom, on field measurements using GPS
and laser devices?
I have found laptops to be too heavy and their battery lives too short for
comfort, unless I can setup shop in the field. Any luck with PDA's or other
hand held devices?
Emmanuel
