CAD Managers
*JR
Message 1 of 7 (731 Views)
archd.shx font character map?
731 Views, 6 Replies
11-17-2005 08:38 AM
Does anyone know where I may be able to find the %%? or ALT+ "guide" for the
archd font? I have been searching for ever in Google but to no avail and I
am getting tired of the old "type it and find out" method, although I did
manage to get the fractions that way.
TIA
Joe
*Miguel
Message 2 of 7 (731 Views)
Re: archd.shx font character map?
11-17-2005 09:05 AM in reply to: *JR
do you have full autocad?
try this attached lsp file. load it with appload.
make sure the textstyle with the archd.shx font is current.
then type character at the command line.
it places a block of text at 0,0 with all the symbols and codes.
Miguel
*Miguel
Message 3 of 7 (731 Views)
11-17-2005 09:09 AM in reply to: *JR
ewps... looks like I cant attach files...
cut and paste this to the command line...then type character. you could
also save it in a text file and name it character.lsp
I found this on cadalyst. thanx Jeff!!
;;Charactr.lsp by Jeff Foster 1/17/96
;;Recommended that this routine be run in a blank drawing
;;This routine generates 16 columns and 16 rows of text
;;consisting of each of the 256 %% characters available
;;in a particular font and numbers each character.
(prompt "\nCHARACTR.lsp loaded ")
(prompt "\nEnter CHARACTER to execute ")
(Defun c:character ()
(setvar "cmdecho" 0)
(setq cnt 1.0)
(setq r_cnt 0.0)
(setq x 0.0)
(setq y 0.0)
(setq sub_y (- y 0.1))
(command "layer" "m" "textfont" "c" "2" "" "")
(repeat 16
(while (<= (fix cnt) (+ r_cnt 16))
(setq pt (list x y))
(setq sub_pt (list x sub_y))
(command "text" "m" pt "0.05" "0" (strcat "%%" (rtos cnt 2 0)))
(command "text" "m" sub_pt "0.05" "0" (rtos cnt 2 0))
(setq x (+ x 0.2))
(setq cnt (+ cnt 1.0))
(setq r_cnt (+ r_cnt 16))
(setq x 0)
(setq y (- y 0.2))
(command "zoom" "e")
(command "zoom" "0.75x")
*JR
Message 4 of 7 (731 Views)
11-17-2005 10:40 AM in reply to: *JR
Thanks for the response but unfortunately I am using 2006 LT at work.
"Miguel" wrote in message
news:5016370@discussion.autodesk.com...
(setq cnt 1.0)
(setq r_cnt 0.0)
(setq x 0.0)
(setq y 0.0)
(repeat 16
(setq x (+ x 0.2))
(setq x 0)
(setq y (- y 0.2))
*Miguel
Message 5 of 7 (731 Views)
11-17-2005 10:49 AM in reply to: *JR
send me the font and I will send you back a dwg...with the code chart.
miguel at zianet dot com
M
*TRJ
Message 6 of 7 (731 Views)
11-17-2005 04:20 PM in reply to: *JR
Open the attached dwg and redefine the style to use the font you want to
see.
"JR" wrote in message news:5016275@discussion.autodesk.com...
TIA
Joe
New Member
alhabi
Message 7 of 7 (555 Views)
07-03-2013 08:59 AM in reply to: *JR
Hi, there,
I have been looking to find away to get the character codes of shx and other cad fonts in autocad. I found old posting with some lsp . I hope you can help me. I am using autocad 2010.
Another question how can I make a font in autocad.... Right to left as in Arabic.
Best regards
AL-Hasan Bin Ali
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
