CAD Managers
CAD Managers
Valued Mentor
mdhutchinson
Message 1 of 4 (1,046 Views)
Anyone using Box dot Net for project replication?
1046 Views, 3 Replies
02-05-2013 08:02 AM
Is anyone using Box dot Net for sharing/syncing AutoCAD Drawing files between multiple servers in different offices?
Keith.Brown
Message 2 of 4 (980 Views)
Re: Anyone using Box dot Net for project replication?
02-20-2013 07:12 AM in reply to: mdhutchinson
Part of the problem with services like box.net is that what happens when two or more people access the files at the same time?  Since each server has its own local copy and then syncs to the cloud there is the opportunity for information to be lost.  If two users are working on the drawing at the same time, User 1 saves the drawing and then User 2 saves the drawing it will overwrite User 1 modifications.   If you just use the service as a file depository and do not use for active drawings then I think they are great.  I use yousendit.com for the same thing and place all of my files in the clould.  I sync certain folders to each of my pc's and have access to all of them at any time.  internet connection required of course.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
Active Contributor
sgold
Message 3 of 4 (964 Views)
02-21-2013 05:40 AM in reply to: Keith.Brown
100% Agree with Keith.  Great as a backup tool, not as a working tool.  Fails when working with Word and Excel files too.  Once you can expect multiple people to want to open the same file at the same time, you'll get conflict files and it all goes bad.
--Scott
Scott G.
Using Inventor 2013/2014 and Vault Basic since 2012
Using Simulation Flow 360 since 2013 (sparingly, bear with me please)
6 years Solidworks (v2006-v2010)
10 years Pro-Engineer (v13-WF2) w/ Intralink (2.0-3.0) w/ Pro/Mechanica
2 years of Mechanical Desktop
AutoCAD since R12
First professional CAD: DrafixCAD
New Member
rolanddaane
Message 4 of 4 (500 Views)
11-21-2013 01:31 PM in reply to: sgold
Guys be honnest.
If people start working on the same file at the same time in Box there is something definitly wrong in the process.
Using Box sync 4 engineers and draftsmen over the entire world can produce drawings and by using relative paths to the xrefs it works.
In Windows explorer Just rightclick the file tou want to work on and hit the lock button.
Think in advantages: Say an xref changes in the fileserver. How do you get the changes into the drawings?
Box notifies you.
Cheers
Roland
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
