Your fix worked, thanks.
"Kevin Anderson" wrote in message
news:EB6239DC11CB5D1081192ADA520397C3@in.WebX.maYIadrTaRb...
> Paul, Sorry I mis-read, I thought you meant from the ADT side. Nevermind.
> The ObjRelUpdate is from inside ADT. I don't know about youre problems
with
> OE2.
> Kevin
> Kevin Anderson wrote in message
> news:67F6814A95C086C27D6CB9E89388A6EF@in.WebX.maYIadrTaRb...
> > Try (type at command line)objrelupdate select object (the Xref), and
> > possibly add a regen.
> > Kevin Anderson
> > Paul Hohn wrote in message
> > news:1BE73612DC7931E2A4BE9597C9DED51C@in.WebX.maYIadrTaRb...
> > > Our Engineering department is using 2000i and our Architects and
> draftsmen
> > > are using ADT2i. The object enabler from Autodesk allows the
engineers
> to
> > > open the desktop files no problem, but when they xref the base drawing
> > into
> > > their files the walls don't clean-up the corners or intersections.
> > > Any thoughts?
> > > Paul Hohn
> > > Computer Systems Manager
> > > L'Heureux Page Werner, PC
> > > 15 5th Street South
> > > Great Falls, Montana 59401
> > > e-mail: lpw-computers@att.net
> > > Phone 406-771-0770
> > > Fax 406-771-0626
