You can have one shared plotter with all needed drivers installed for it on
the print server. On print server select printer/plotter properties, shared
tab and in the lower right click where it says "additional drivers" and add
the needed drivers. When you add the printer/plotter to the workstation it
will automatically install the correct driver for that machine OS. Create a
PC3 file that references the shared printer/plotter name and both 32 and 64
bit machines can use the same PC3 and same shared printer/plotter. Works
here with no problems!
wrote in message news:6373263@discussion.autodesk.com...
from our experience it appears that you need seperate PC3 files for 32bit
and 64bit machines as the 64 bit and 32 bit printer drivers that a printer
uses have different names which means 1 PC3 file for both 32 bit and 64 bit
does not work.....our IT guys say you can not rename drivers to make the
64bit and 32bit have the same name....not sure if this is true?
Autodesk even seem to imply you need a seperate PC3 file for each operating
system.....although i do not think this is the case...see Autodesk support
response to my question about the possibility of having 1 PC3 file work for
both 32bit and 64bit...
Dear Mark Doel,
Thank you for choosing Autodesk Support. Here is the recommended resolution
to your Support Request:
same as what I had said in my previou reply. no official document talk
about it . but we think
"Definitely our customer needs to create a different PC3 for each operating
system.
Windows system print drivers are operating system specific, a PC3 file that
was created from a system driver will work only on computers that have the
same operating system and use the same system driver version.
32Bit and 64Bit are considered different Operating Systems even if is the
same OS brand, (XP, Vista or 7)
hope the answer is ok for you.
Best regards,
Richard Ren
Autodesk Support Team
You can provide extra information, including data files, by clicking here or
replying to this email.
