Buzzsaw Forum Archive
Welcome to Autodesk’s Buzzsaw Forums. Share your knowledge, ask questions, and explore popular Buzzsaw topics.
Viewing Photos
2 REPLIES 2
345 Views, 2 Replies
Viewing Photos
Trying to find a solution for viewing photographs on Buzzsaw. Currently,
photographs are not resized to fit within the available window in buzzsaw as
they are in IE on its own. This forces a user to have to scroll left/right
and up/down to see the entire picture.
Any ideas as to how we can force the image to resize and fit into the entire
window?
2 REPLIES 2
It looks like the image resizing functionality works a bit funky in IE;
you'll see the same resizing problems if you create an HTML page containing
an tag rather than viewing the image directly in IE. You can
work-around this by using a height (or width) attribute on the tag
with a value of "100%", this allows the images to resize in the ProjectPoint
client.
With some (considerable?) effort, you can use DHTML and ActiveX objects to
generate the HTML dynamically so that you wouldn't have to create a separate
HTM file for each image.
Dan
"Wayne James" wrote in message
news:F1E055E6790A12583DD3075A57D8156E@in.WebX.maYIadrTaRb...
as
left/right
entire
> window?
didrby
Try this:
Click TOOLS, and then PREFERENCES
Under the FILE TYPES tab, click on RASTER FILES
Then in the Drop Down box, select BUZZSAW VIEWING CONTROLS
Then hit OK
Seems to work ok on my version.
