Buzzsaw General Discussion
Active Contributor
clastrilla
Message 1 of 1 (311 Views)
Syncing Vault ipt/iam's to Buzzsaw
311 Views, 0 Replies
02-05-2014 01:16 AM
With Buzzsaw Project Sync, you can use the lifecycle transitions in Vault to sync up files to Buzzsaw, e.g. when a file is released, it gets synced to a Buzzsaw site.
This is fine for DWG's, as the Buzzsaw webclient seems to be able to generate previews for these, but how about for IAM's and IPT's?
I was thinking, when Vault creates the DWF for the IPT/IAM, you can set the visualization files to be saved to a local directory on the PC, then use Buzzsaw Sync to sync that up at intervals. But I think this is maybe a bit too convoluted.
Is there a better way to do this? The goal is for someone to preview the IPT/IAM via the Buzzsaw interface.
Need installation help?
New Buzzsaw Category!
The Buzzsaw forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
