Buzzsaw General Discussion
Valued Contributor
clastrilla
Message 1 of 1 (339 Views)
Syncing Vault ipt/iam's to Buzzsaw
339 Views, 0 Replies
02-05-2014 01:16 AM
With Buzzsaw Project Sync, you can use the lifecycle transitions in Vault to sync up files to Buzzsaw, e.g. when a file is released, it gets synced to a Buzzsaw site.
This is fine for DWG's, as the Buzzsaw webclient seems to be able to generate previews for these, but how about for IAM's and IPT's?
I was thinking, when Vault creates the DWF for the IPT/IAM, you can set the visualization files to be saved to a local directory on the PC, then use Buzzsaw Sync to sync that up at intervals. But I think this is maybe a bit too convoluted.
Is there a better way to do this? The goal is for someone to preview the IPT/IAM via the Buzzsaw interface.
New Buzzsaw Category!
The Buzzsaw forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
