Hi, Using AutoCAD 2014 and Buzzsaw sync, the "Rename and Renumber" feature in the Sheet Set Manager doesn't fully work. It allows you to change the number and title of sheets, but does not allow you to rename the layout itself, or rename the file to match. The behavior works normally outside of Buzzsaw Sync folders.
Is there a permissions conflict or option that needs to be changed?
