I agree. This doesn't really sound like a Buzzsaw problem, but please let us
know if you have anymore questions.
John Helfen
BCS Technical Support
"Jamie Richardson" wrote in message
news:3EEF7A83.996337CD@ns.ericksenroed.com...
> Thanks for the info, we have done all of this. still does not work. This
is only
> happening on our win 98 machines. I can't ping anything from our win 98
> machines. This is probably a topic for a different news group, unless
anyone has
> any other ideas. Thanks for the help.
> By the way thanks for the webdav.buzzsaw.com. Are these urls accessible to
> anyone. We only use Buzzsaw because our clients use it. Every time a new
version
> of Buzzsaw is issued we have to go through this run around allowing new
url to
> pass through our firewall.
> folders.projectpoint.com,
> folders.buzzsaw.com,
> projectpoint.buzzsaw.com,
> webdave.buzzsaw.com, etc
> Is there a TID somewhere on this. Are some of these urls not used anymore
and we
> can remove them from our allow list to clean things up. Just looking for a
> quicker way to roll out new versions with little problems. FYI the problem
of
> not being able to access buzzsaw with win 98 machines seemed to be only
> problematic after installing Project point Version 4.0.737.16.
> thank you,
> Jamie Richardson
> CAD Coordinator
> Technical Support wrote:
> > Jamie,
> > Pass the following information on to your IT team to make sure they have
> > this info configured properly in your firewall/proxy server.
> > Configure your proxy server/firewall appropriately: In the event that
the
> > above test fails, please make sure that the following IP addresses are
> > allowed:
> > · Projectpoint.buzzsaw.com (64.75.26.36) ports 80 (HTTP) and 443
> > (HTTPS)
> > · Webdav.buzzsaw.com (64.75.26.93) ports 80 (HTTP) and 443 (HTTPS)
> > · Configure your proxy server and firewall to allow access via
WebDAV.
> > Note: You may require assistance from your internal IT support staff to
do
> > this.
> > You may also want get them involve now. There is obviously something in
your
> > network blocking you from getting to our servers.
> > Thanks,
> > John Helfen
