I'm using C3D 2013 to xref drawing attachments into my drawing file via a Buzzsaw 2013 link.
When I reopen my drawing, the Buzzsaw-based xrefs do not load even though a valid URL (https:\\webdav.buzzsaw.com\etc.) appears to be listed as the xref path.
I can reload the file by manually selecting the 'Attach' option on the External Reference pane when right-clicking the xref label on the list, and then manually travelling the file path tree to select the appropriate file, but wanted to know what I need to do to get these kinds of xrefs to (re)load "automagically" upon loading the drawing file containing them.
Do I need to be using Buzzsaw Sync or some other application?
Note that I am *not* signed into Autodesk 360 pretty much ever.
Sorry if this has already been addressed, but some posts here are very difficult to follow, due to their being one large run-on paragraph that is not easily parsed.
Jeff
Hello Jeff,
Thank you for participating in the community.
Are you uploading the master drawing and including all xrefs?
It does seem Sync may need to be used to ensure the latest version of all files are being uploaded to Buzzsaw.
Knowing your full workflow would be helpful. You can reach our helpdesk using the below URL to walk through your workflow process so we can try and identify any issues.
Best Regards.
Nick
