Buzzsaw General Discussion
Valued Mentor
Lancasterm
Message 1 of 4 (871 Views)
Buzzsaw - Vault
871 Views, 3 Replies
08-21-2007 11:57 AM
We are a manufacturing company that was originally looking at Streamline for our collaboration needs. However when we took a side trip into the BuzzSaw environment, we decided that was the path (to implement) to follow. However in reviewing Streamline features again today, I discovered it (Streamline) can work with the vault and publish directly from it.
Does anybody know if ProductStream can do the same?
Regards
Mark L.
TresM
Message 2 of 4 (871 Views)
Re: Buzzsaw - Vault
08-24-2007 12:09 PM in reply to: Lancasterm
Yes it can. Productstream is our release mgt system. Meaning once a part or assembly is released to mfg, productstream will lock the file down in Vault so no one can make changes to it because it is released. If you want to make changes then their is eco workflow built in to modify the revision.
If you would like more information, please contact Daniel Doyle at daniel.doyle@autodesk.com.
Distinguished Contributor
varindersra
Message 3 of 4 (812 Views)
Re: Buzzsaw - Vault
11-30-2010 10:50 AM in reply to: TresM
Can Buzzsaw replace vault webclient. I mean can buzzsaw diplay all the files in the vault with same folder structure and also diplay properties associated with the files all published automatically from vault. And does the permission and users access from vault gets transfer automatically.
Employee
joan.allen
Message 4 of 4 (381 Views)
Re: Buzzsaw - Vault
06-16-2011 10:56 PM in reply to: Lancasterm
There is a new feature for Vault Collaboration 2012 and Buzzaw 2012 called called Vault Project Sync. This enables a Vault administrator to select a folder in the Vault and synchronize it with a folder on Buzzsaw, so that Vault files can be made available to project team members outside of your company.   See this link below for instructions on how to get Project Sync.
http://autodeskmfg.typepad.com/blog/2011/06/downloading-project-sync-for-autodesk-vault.html
New Buzzsaw Category!
The Buzzsaw forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
