Buzzsaw Forum Archive
Welcome to Autodesk’s Buzzsaw Forums. Share your knowledge, ask questions, and explore popular Buzzsaw topics.
Buzzsaw Implementation Questions - No:7
2 REPLIES 2
200 Views, 2 Replies
This one is related to user management.
What i will be first standardizing is the roles. Eg.Architect, engineer, his permission levels, his rights etc which are set for once.
Then, when I start creating an user, i should be able to use this role as a template.All I will be doing is to just provide the user name and his email id + other info, all others are set based on the role template.
is this possible ?
TIA
2 REPLIES 2
Yes. You can do this. Are you doing the 30-day trial site? If so, Look at "copying members". You'd create the "standard" architect member, set permissions for this user......then copy/rename the user every time you need to add a new architect to Buzzsaw.
Thanks a lot!! That was a good tip.Will try and let you know.
