Buzzsaw Developer
GeeHaa
Message 1 of 4 (2,134 Views)
Upload a file
2134 Views, 3 Replies
08-18-2008 06:58 AM
Hi I'm trying to upload a file and I'm getting the error message Object does not support this property or method
on this Line. Any help would be much appreciated
flder.AddFile (pfile)
Dim PPsess As PPSession
Dim flder As New PPFOLDER
Dim pfile As New PPFILE
Set PPsess = New PPSession
PPsess.LogIn loginName, password, "https://webdav.buzzsaw.com/Sitename"
Set flder = PPsess.GetResource("/test/Cad/")
pfile.LocalPath = "c:\lisp\IDR.lsp"
pfile.Name = "IDR.lsp"
PPsess.LogOut
GeeHaa
Message 2 of 4 (2,134 Views)
Re: Upload a file
08-18-2008 10:30 AM in reply to: GeeHaa
By The Way, I'm using VBA
New Member
Makoto
Message 3 of 4 (2,134 Views)
Re: Upload a file
08-25-2008 12:57 AM in reply to: GeeHaa
Hello geehaa,
You must use "Upload" method to upload a file to Buzzsaw.
Please try the following code.
Dim PPsess As New PPSession
Dim flder As String
Dim pfile As String
PPsess.LogIn loginName, password, "https://webfolders.buzzsaw.com/Sitename"
flder = "/test/Cad/"
pfile = "IDR.lsp"
PPsess.Upload "C:\lisp\" & pfile, flder & pfile, APPLY_TO_RESOURCE_ONLY
PPsess.LogOut
GeeHaa
Message 4 of 4 (2,134 Views)
Re: Upload a file
08-25-2008 04:27 AM in reply to: GeeHaa
That works.
Thanks!
Need installation help?
New Buzzsaw Category!
The Buzzsaw forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
