Buzzsaw Developer
Active Contributor
wouterbleumink
Message 1 of 1 (1,508 Views)
regsvr32 ProjectPointClient.dll fail's
1508 Views, 0 Replies
06-17-2011 05:03 AM
I am building an application using VB.NET wich uses the ProjectPointClient.dll
When distributing the application using an installer everything is fine. But when i start my application it crashes stating some COM error.
If i install the API toolkit on that machine also, the application run's fine.
I tried it on another machine, same error. This time i tried to manually register the ProjectPointClient.dll using regsrv32, but this fails (can't be loaded).
I am using the latest API toolkit (ProjectPointClient.dll version 2012.120.8726)
Can somebody help me solve this?
Wouter Bleumink
New Buzzsaw Category!
The Buzzsaw forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
