Buzzsaw Developer
New Member
ingedwin
Message 1 of 4 (2,360 Views)
Problem getting access to Buzzsaw
2360 Views, 3 Replies
05-24-2006 12:38 PM
I was using a program made in VBA to get contents in Buzzsaw until one day start receiving the following error without doing any modification in the program:
Run-time error '-2147220986 (80040206)':
Method 'GetFolderContents' of object 'IPPScripting' failed
This error came from the following row in the program:
Set collection = PPScriptObj.GetFolderContents(resourceURL, "xxxxx", "xxxxxxx")
The resourceURL use different paths, so one sample is the following:
"https://webfolders.buzzsaw.com/GEATSGlobalProjects/OGE Colbert/Drawings/Originals/SP_C"
Did Buzzsaw made any modification or upgrades that probably affect the access to Buzzsaw via API program?
Edwin
*Scott Sheppard [Autodesk]
Message 2 of 4 (2,360 Views)
Re: Problem getting access to Buzzsaw
05-24-2006 02:08 PM in reply to: ingedwin
Try https://webdav.buzzsaw.com/GEATSGlobalProjects - I heard this from
another user. I have not verified it myself.
wrote in message news:5185155@discussion.autodesk.com...
program:
"xxxxxxx")
Edwin
Member
Ryan Rogers
Message 3 of 4 (2,360 Views)
10-23-2006 06:38 AM in reply to: ingedwin
"webfolders.buzzsaw.com" and "webdav.buzzsaw.com" can normally be used interchangeably.
The problem Edwin ran into in late May there was a patch to our servers that had an inadvertent side effect of making "webfolders" not work temporarily. The problem was promptly corrected. However, "webdav" was not affected, and as Scott pointed out would have been a valid workaround.
Ryan Rogers
CPM Engineering
Autodesk Inc.
Member
jljf_hh
Message 4 of 4 (2,346 Views)
08-23-2010 09:24 PM in reply to: ingedwin
i have get the same question to you.
did you resolve this error?
New Buzzsaw Category!
The Buzzsaw forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
