Buzzsaw Forum Archive
Welcome to Autodesk’s Buzzsaw Forums. Share your knowledge, ask questions, and explore popular Buzzsaw topics.
Problem getting access to Buzzsaw
3 REPLIES 3
ingedwin
2573 Views, 3 Replies
I was using a program made in VBA to get contents in Buzzsaw until one day start receiving the following error without doing any modification in the program:
Run-time error '-2147220986 (80040206)':
Method 'GetFolderContents' of object 'IPPScripting' failed
This error came from the following row in the program:
Set collection = PPScriptObj.GetFolderContents(resourceURL, "xxxxx", "xxxxxxx")
The resourceURL use different paths, so one sample is the following:
"https://webfolders.buzzsaw.com/GEATSGlobalProjects/OGE Colbert/Drawings/Originals/SP_C"
Did Buzzsaw made any modification or upgrades that probably affect the access to Buzzsaw via API program?
Edwin
3 REPLIES 3
in reply to: ingedwin
Try https://webdav.buzzsaw.com/GEATSGlobalProjects - I heard this from
another user. I have not verified it myself.
wrote in message news:5185155@discussion.autodesk.com...
program:
"xxxxxxx")
Edwin
Ryan Rogers
"webfolders.buzzsaw.com" and "webdav.buzzsaw.com" can normally be used interchangeably.
The problem Edwin ran into in late May there was a patch to our servers that had an inadvertent side effect of making "webfolders" not work temporarily. The problem was promptly corrected. However, "webdav" was not affected, and as Scott pointed out would have been a valid workaround.
Ryan Rogers
CPM Engineering
Autodesk Inc.
i have get the same question to you.
did you resolve this error?
