Hello geehaa,
You can get the resources in a site by using the following methods.
1. Using GetFolderContents methods in PPScripting
If you set "https://webfolders.buzzsaw.com/sitename/test" to sURL,
you can get all resources name in test folder.
Dim oPPcol As IPPResourceCollection
Dim oPPres As IPPResource
Dim sFolderList As String
sFolderList = ""
oPPcol = oPPScripting.GetFolderContents(sURL, sUsername, sPassword)
For Each oPPres In oPPcol
sFolderList = sFolderList & ", " & oPPres.Name
Next
MsgBox(sFolderList)
2. Using GetFolderContentsList methods in PPScripting2
you can get XML file (Folder.xml) of all resources list in test folder.
Dim oPPScript2 As New PPScripting2
Dim fRes As String
fRes = oPPScript2.GetFolderContentsList(sURL, sUsername, sPassword)
Dim Fno As Integer
Fno = FreeFile()
FileOpen(Fno, "C:\Folder.xml", OpenMode.Output, OpenAccess.Write)
PrintLine(Fno, fRes)
FileClose(Fno)
MsgBox("Done!")
I recommend that you check sample programs in ProjectPoint API toolkit.
You will be able to understand how to use the methods in the API samples.
