Buzzsaw Forum Archive
Welcome to Autodesk’s Buzzsaw Forums. Share your knowledge, ask questions, and explore popular Buzzsaw topics.
Getting a list of available projects
2 REPLIES 2
GeeHaa
2207 Views, 2 Replies
Is there a way to get a list of available Projects?
I've tried.
Dim PPprojects As PPResourceCollection
Set PPprojects = PPsess.GetResource("SiteName")
I get a type mismatch error.
2 REPLIES 2
GeeHaa
in reply to: GeeHaa
I have also tried this.
Dim PPProj As PPPROJECT
Dim ppsit As PPSITE
Set ppsit = New PPSITE
ppsit.AttachSession PPsess
Set PPprojects = ppsit.SubProjects
I get a Subprojects method failed error after the above line
For Each PPProj In PPprojects
CBO_Projects.AddItem PPProj.Name
Next PPProj
Any help would be appreciated.
makoo
in reply to: GeeHaa
Hello geehaa,
You can get the resources in a site by using the following methods.
1. Using GetFolderContents methods in PPScripting
If you set "https://webfolders.buzzsaw.com/sitename/test" to sURL,
you can get all resources name in test folder.
Dim oPPcol As IPPResourceCollection
Dim oPPres As IPPResource
Dim sFolderList As String
sFolderList = ""
oPPcol = oPPScripting.GetFolderContents(sURL, sUsername, sPassword)
For Each oPPres In oPPcol
sFolderList = sFolderList & ", " & oPPres.Name
Next
MsgBox(sFolderList)
2. Using GetFolderContentsList methods in PPScripting2
you can get XML file (Folder.xml) of all resources list in test folder.
Dim oPPScript2 As New PPScripting2
Dim fRes As String
fRes = oPPScript2.GetFolderContentsList(sURL, sUsername, sPassword)
Dim Fno As Integer
Fno = FreeFile()
FileOpen(Fno, "C:\Folder.xml", OpenMode.Output, OpenAccess.Write)
PrintLine(Fno, fRes)
FileClose(Fno)
MsgBox("Done!")
I recommend that you check sample programs in ProjectPoint API toolkit.
You will be able to understand how to use the methods in the API samples.
