Buzzsaw Developer
Valued Contributor
masa10789
Message 1 of 3 (1,755 Views)
create Buzzsaw object
1755 Views, 2 Replies
01-22-2007 10:44 AM
I was trying to write a simple lisp routine to open the Buzzsaw app. Something like (vlax-get-or-create-object "projectpoint.application"). This doesn't work, does anyone know the correct app name to use?
I know how to access the session and scripting for programmatically accessing files/folders/projects, etc, but I just want a simple program to open the Buzzsaw GUI only, just as if the user double clicked on the Buzzsaw desktop shortcut.
*Scott Sheppard \(Autodesk\)
Message 2 of 3 (1,755 Views)
Re: create Buzzsaw object
01-22-2007 11:20 AM in reply to: masa10789
John Schmier wrote an article about invoking the DWF Viewer from AutoCAD:
http://dwf.blogs.com/beyond_the_paper/2006/11/invoking_the_au.html
Can you just change
C:\\Program Files\\Autodesk\\Autodesk DWF Viewer\\DWFViewer.exe
to
"C:\\Program Files\\ProjectPoint-7\\ProjectPoint.exe"
and that will work?
wrote in message news:5459780@discussion.autodesk.com...
desktop shortcut.
Valued Contributor
masa10789
Message 3 of 3 (1,755 Views)
01-22-2007 12:58 PM in reply to: masa10789
thanks, that's what I was thinking about. I just wasn't sure if there was a better way to do it.
New Buzzsaw Category!
The Buzzsaw forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
