Buzzsaw Forum Archive
Welcome to Autodesk’s Buzzsaw Forums. Share your knowledge, ask questions, and explore popular Buzzsaw topics.
Buzzsaw Interactions using WebDAV
1 REPLY 1
theMagicFarmer
475 Views, 1 Reply
Has anybody used Microsoft's WebDAV to interact with Buzzsaw through an applicaiton? Below is some sample code that I pulled off Microsoft's Developer Network. I think this could work, but there is so much information out there on this topic that it gets confusing as to which approach to use.
AUTODESK DEVELOPERS:
Can this API be used to do file uploads to Buzzsaw?
Private Sub Command2_Click()
Dim xmlReq As MSXML.XMLHTTPRequest
Set xmlReq = CreateObject("Microsoft.XMLHTTP")
Dim xmlObj As MSXML2.IServerXMLHTTPRequest
Set xmlObj = CreateObject("Microsoft.XMLHTTP2")
'Set aa = xmlObj.Open(serverString, URLstring, varAsync, User, pwd)
xmlObj.Open "PUT", URLstring, False, User, Password
' xmlReq.Open "PUT", strSubURL, False, strUserName, strPassWord
' If strText "" Then
' xmlReq.setRequestHeader "Content-Type", "message/rfc822"
' xmlReq.send strText
' End If
End Sub
1 REPLY 1
in reply to: theMagicFarmer
Yes it can be done. I know our customer applications group has helped
customers set up automated processes to do uploads and downloads. You would
use the URL https://webfolders.buzzsaw.com/sitename with your Buzzsaw user
name and password as credentials.
wrote in message news:5063816@discussion.autodesk.com...
approach to use.
' End If
End Sub
