I'm still having trouble with my model. It should be performing better than it is reporting. I know that the values for the window inputs are incorrect. It seems that as a Revit user, I can only select my window option from a pulldown list. Is this the only option? Can I specify the U-value and the Solar heat gain coeeficient of the glass independent of the drop down? Can this be done in Green Building Studio instead of revit?
I would like to input U=0.106, SHGC = 0.61
Chris
Hi Chris,
I am sorry to hear that you are still having issue with your model. The window type that you are trying to use is super high performance window. We do not have a window type with similar performance in our list. Can you provide us more details about this window (Window6 file) so we can add it to our list.
You can always choose something close to it like: Quadruple LoE Films (88) 3mm/8mm Krypton, U-Value: 0.66 W / (m²-K) (0.116 Btu/hr ft2 oF), SHGC: 0.45 , Vlt: 0.62 in Energy Cost Range tab of Results and compare or in Project Solon.
You can see the details on this window type in alternative runs that are automatically created beside your base run:
Or you can set a run set base on the various window types for each face of the model you have:
Hope this helps you. Please let me know if you need any help on assigning runst to Revit Results and Compare.
Here to help if additional clarification is needed, otherwise please accept as a solution so that others can benefit from this information.
