Hi Autodesk community
I am experiencing a problem with energy analysis run on Revit 2015 doing BPA certificate.
The message is:
''You do not currently have access to this service
Your license period for the sharing service has ended.''
I have tried:
- I reinstalled Revit 2015 with my student license serial number
- I did reassure then I signed in with the account on my email which is registered as a student account in Autodesk education community
- I have signed in to Green Building Studio where it says that I have trial license for 30 days which is strange because I am doing BPA course it should be a student license
I sent message to the help desk they said that I have to post on the forum that Autodesk support could help me.
Could you please help me with this thing
If you are using the same educational email account to login to GBS, it should automatically change your account to educational on GBS as well. Can you try in Revit and see if you have access/use other cloud service like rendering in the cloud?
Can you provide your account user name?
Hi Mohammed,
I can give you my account details if you tell me how to do so.
Shall I type my email right here in the forum? Could you check the details by knowing my name IlyaUfim?
Hello Mohammad
Also would you be able to check the following error - I answer the question right but it was not count for the right. Could you check please the issue in those two tests:
Software Exercise: Audubon Airflow
External Airflow Quiz
Files attached
Hello Mohammad
Would you be able to tell me when you can check my account on the errors listed above?
Thank you,
Ilya
Hi IlyaUfim,
Sorry for the delay. I was very busy last week which was the week for Autodesk University and I did not get a chance to answer the issues on the forum.
I have forwarded your issue with BPAC grading system to the sustainability education team. They will contact you soon to solve the issue.
We tracked down the issues about the accounts and your account issue should be solved. If you are still having problem, please send your email address to mohammad.asl@autodesk.com. I will follow p with you via email.
Hi Ilya,
Sorry you were having difficulties with the quiz, and thank you for including screenshots to better diagnosis the problem. It seems that while you were entering the correct answers, the grading system was not marking your answers as correct. I’ve corrected the grading system, and your account should be updated accordingly.
Thanks for letting us know about the issues and apologies for any inconvenience!
-Stephanie
Hello Stephanie
Thank you for your help with the quiz. Thank you for creating this course.
However, I am still experiencing difficulty with energy analysis run on Revit 2015. I would like to know if there is anything I can do or provide any information to solve this issue. (You might read my first posts above to get the information about problem with running energy analysis on Revit 2015)
Please help me,
Ilya
The suggestions Mohammad provided previously are the same that I would offer. We are still troubleshooting the issue on our end to understand what is causing the problem.
Hi
Would you check thus issue as well please.
The question 7 on the screenshot
I also want to confurm that I still have no access to Energy Analysis run on Revit 2015. Could someone help me please.
Ilya
Your response to question 7 is incorrect. This software exercise requires you to compare climate charts for the three locations. Question 7 is not asking about the Beaufort chart in general, but in the context of the previous question; Which location experiences the highest windspeeds? In question 7, you need to figure out what the windspeeds of that location translate to on the Beaufort scale.
Does that make sense?
I had the same problem and really pissed me off. I spent a lot of time surfing different pages and did different things with no Result.
Finally I found it. The problem is not with your registeration. You can follow the link bellow:
good luck
Hi cvinothkumarc456,
Do you have problem with running energy analysis via Revit? If so please answer the following questions. We have updated our system and it should work properly now.
Please make sure that you have done all the steps. If you still have the same issue, please send your account info to bpa.team@autodesk.com and mention my name on the heading. I will check your account and will follow up with you via email.
Hi there,
Just following up on this thread--if anyone is still having trouble, please let us know. If you have an educational account and are experiencing issues accessing Insight 360, Revit Energy Analysis, or Green Building Studio, please fill out this form:http://goo.gl/forms/M7JrNSdOzM
Once you complete the form we will reply back to you via email once your account issues have been resolved. We apologize that so many of you are experiencing this error, but we are working to have a solution soon!
-Stephanie
I am also experiencing the same problem and done the following but still have no hope. I already fill up the google form but stil dont have any feedback about this problem.I hope you can help me about this. I am taking the BPAC and can't go further because of this problem. Thanks
Can you login to https://accounts.autodesk.com?
Yes, I can Login
Can you still access/use other cloud service like rendering in the cloud in Revit?
No, I cant use the cloud service and I don't know why
Can you login to GBS with your educational account https://gbs.autodesk.comt? If not can you create a new account and try to login?
Yes, I can login and my two accounts says it is active
What is your account user name?
I created two accounts just to check if it will work if I created a new one and my usernames are.
- archt.jamesalbertnealega@gmail.com
- jamesalbertnealega@gmail.com
If anyone is still having trouble, please let us know. If you have an educational account and are experiencing issues accessing Insight 360, Revit Energy Analysis, or Green Building Studio, please fill out this form:http://goo.gl/forms/M7JrNSdOzM
Meanwhile you can use this public account to finish your certificate/assignment. Please delete your project after you are done.
UserId: mrah
Password: Student01
