Hello everyone, i've a little problem, i installed Building Ops revit Add-ins...but i can't find in the add-ins ribbon...:(
thanks for the reply
Solved by katie.murff. Go to Solution.
Hi @EnricoG,
Sorry about the trouble. Which version of Revit are you on? Did you make sure to install the correctly by downloading the Building Ops Add-in for Revit Technology Preview from the Building Ops page > All Buildings > Settings (scroll to the bottom of the page) Once the add-in is installed, open the model in Revit > click the Add-Ins tab > Export (under Building Ops).
Please look for the file "BuildingOpsExporter For Autodesk Revit.addin" under the folder "C:\ProgramData\Autodesk\REVIT\Addins\2016".
If the file is in a different place, move it to C:\ProgramData\Autodesk\REVIT\Addins\2016 and you should be all set.
Best,
Katie
now the addin is in right folder...but now appear an allert (screen attchement), what's the right location of ALL file???
Revit version 2016, i've downloaded building Ops from the web site like you said...but now there's a warning " dll's file not exist"
Sorry for the trouble @EnricoG,
Could you post a screenshot of this error message? This is occurring when you download or when you try to install?
Hi Enrico,
I'm sorry for your troubles.
The dll path in Assembly property should be the same as the installation path. If it is not, please change it to the same path. Here are the steps:
Katie
ok, i write the right directory in the dll file 🙂 with right name and at (screen attachement)
When i see on the asse detail, in the section 3D model there is "in Syncing"...but where is the model syncing??? in a viewr of Building Ops or A360?
Hi there,
Can anyone provide me the link to download the Revit add-in for uploading a Revit model ?
Regards
Hi Saul,
You may download the Revit Add-in for Building Ops at the bottom of the All Buildings Settings page.
Katie
hi katie
I have the same problem.
I installed the add'ins from the building ops site (in the bottom setting) and i do not see the export key in revit 2016.
I tryed to found the file in = Autodesk > Revit > Addins > 2016. but i do not find the building ops exporter folder so I can't edit the text file and save.
thank you
Pietro M
Hi Pietro,
The export code may be found on the building details page that you are exporting to.
In Building Ops, go to the dashboard for the target building. Click on the building tile. Then you will see Generate Export Code.
Katie
hi
thank you for your answer. probably I did't explain well in my terrible english.
the problem is that i dont find the ribbon and the file dll in the folder programdata>revit>addins>2016 so I can't modify the code string.
thank you for your time
Can you send me a screenshot of what you have please?
Katie
If you search your computer for BuildingOpsExporter, is a file found? If so, you can copy and paste it to the correct destination folder.
Katie
Hello everyone, i have the same problem for revit 2018, i am not able to export the model BIM 360 Ops.
Thank you
