The reporting feature in BIM 360 Field is extremely valuable! But! Current enterprise users cannot use the reporting to help trend across business unit projects or organization without help from Autodesk! The reason why we purchased this tool is to get this type of reporting in a more automated way.
There should be higher flexibility in ther reporting module. Each project is a bit different due to the customer needs! We should be able to configure reports easily to help communicate the value or challenges we face on projects!
When will this be available? Checklists are useless unless we learn from the trending across projects, not just one project!
Here is (one page of many) an example of a MANUAL report from excel based from an Autodesk Generated Report from our Implementation manager. There are at least 4 steps of NON-VALUE ADD to get to the desired output! Now think about the challenges with Root Cause trending, etc...
Shouldn't BIM 360 Field be able to do this?
