I've recently started using the BIM 360 glue app for the iPad and on the whole it's great. However the selection resolution seems to be set to Last Object as a default which I can't find any way to change. The model file I'm viewing contains a lot of information in the form of block attributes which are normally visable in Properties in Navisworks when the selection resolution is set to First Object. Is there any way to change this in the iPad app, or perhaps access the selection tree?
Domenic Cunningham
Solved by s.hamel. Go to Solution.
Solved by anil_mistry. Go to Solution.
Hello Domenic,
Thank you for participating in our community!
We are aware of this issue and our engineering team is working on resolving this issue. We will provide you an update as soon as one is available. Workaround would be to create selections sets in the Navisworks and then GLUE and then Share with Field.
Please, let me know if this helps.
Thank you!
Best regards,
Any chance you could give me directions on how to perform the workaround. I have custom property sets that show up for my equipment in Navisworks but it does not show up in Glue for some reason.
Is there a fix yet to set the selection resolution preference in Glue ? Similar to as we can do in Navisworks?
