BIM 360 Glue Forum
Welcome to Autodesk’s BIM 360 Glue Forums. Share your knowledge, ask questions, and explore popular BIM 360 Glue topics.
Selection Tree / Selection Resolution on BIM 360 Glue iPad app
4 REPLIES 4
domenic.cunningham
769 Views, 4 Replies
I've recently started using the BIM 360 glue app for the iPad and on the whole it's great.  However the selection resolution seems to be set to Last Object as a default which I can't find any way to change.  The model file I'm viewing contains a lot of information in the form of block attributes which are normally visable in Properties in Navisworks when the selection resolution is set to First Object.  Is there any way to change this in the iPad app, or perhaps access the selection tree?
Domenic Cunningham
4 REPLIES 4
Hello Domenic,
Thank you for participating in our community!
We are aware of this issue and our engineering team is working on resolving this issue. We will provide you an update as soon as one is available. Workaround would be to create selections sets in the Navisworks and then GLUE and then Share with Field.
Please, let me know if this helps.
Thank you!
Best regards,
Anil Mistry
Technical Support Specialist
jalvino
in reply to: anil_mistry
Any chance you could give me directions on how to perform the workaround. I have custom property sets that show up for my equipment in Navisworks but it does not show up in Glue for some reason.
s.hamel
in reply to: jalvino
Domenic, when you have the Properties panel up, the second row of it shows the object selected and Arrows to navigate up or down the tree.
For instance when I select a wall, it shows as "< Basic Wall" and you can use that left arrow to traverse up the tree to what you actuall want.
So while there is no method for defaulting to first object, you can still get to the information fairly quickly.
Shayne
Shayne Hamel
Manager, Principal Software Engineering
Is there a fix yet to set the selection resolution preference in Glue ? Similar to as we can do in Navisworks?
