Several of our users are having issues opening a merged model. Immediately after clicking on a merged model, the model viewer begins to open and then the program crashes and shuts down. We've tried upgrading graphics card drivers and changing settings but no great results. Still crashing. Any recommendations or help?
Solved by asettino. Go to Solution.
Solved by don_simpson. Go to Solution.
Hi Jon,
Thank you for participating in our community!
In a separate conversation through the related support ticket, you had mentioned that the affected users have NVIDIA NVS 4200M graphics cards. Please have them download and install the driver from the link below to one of the machines and give it a try.
http://www.nvidia.com/download/driverResults.aspx/76996/en-us
Please let me know if additional help is still needed.
Don
Don Simpson
If they're able to open one of the individual models in the project have them open one of those models and go to options and then the advanced tab. Change the graphic system from Autodesk to Basic. They should be able to open merged models after that is changed.
If they can't open any models, have one of the users who is having the issue log onto their Glue account on one of the users computers who is not having the issue and can open models. They should be able to open a model on the users machine that does work. Once a model is open, go to options and then the advanced tab. Change the graphic system from Autodesk to Basic. That setting should hold for the user. When they go back to their own computer and log in they should be able to open models now.
I've created a very simple project to invite people to for this purpose. If they can't get to someone else's computer I invite them to the simple project which they can open without issue and change the same setting.
Hope that helps. I'm not sure why both Navisworks and Glue have the default setting set to Autodesk render. It just slows everything down and seems to casue issues.
