Hi everyone,
I want to trey BIM 360 Glue, but when i try to use it in Revit Add In send me this message "BIM 360 Glue. Server did not recognize the value of HTTP Header SOAPAction:http://horizontal-lcc.com/GetUserIdByName." and i don´t know what to do next, i hope you can help me.
I saw something related but wih vault and i don´t undertand the solution.
Thank you in advance!
Solved by anil_mistry. Go to Solution.
Hello Roberto,
What version of Revit you are working with? Would you be able to provide screen shot of error message?
Thank you and I look forward to your reply!
Best regards,
Hi Anil,
Im using Revit 2015.
Attached image of the error.
Thank you for the replay!
Hello Roberto,
Thank you for your reply. Please, go to the Autodesk Application Manager, click on "Updates" and look for updates back in June which is when the BIM 360 Glue plug-ins was last updated.
Please, let me know if this help.
Thank you and have a great day!
Best regards,
Hi Anil,
It worked what you recommended, thank you very much.
I want to know how can i show in BIM 360 Glue the 4D simulate secuence drom Navisworks on an Ipad, ¿this is even posible? or ¿how can I do it?
Thank you!
I just want to follow up on your post.
Are you still experiencing this issue? This should have been resolved when updating the Glue plug-ins. Please go to Control Panel>Programs and Features and look for the add-ins. It should say version 4.34.2701.
Please let us know if you are still continuing to receive the error message after verifying that you have the latest add-ins installed.
Thank you!
Frederick
Hi Frederick,
Thanks for the follow.
Everything went well with Anil solution.
Keep in touch.
Thank you
Anil
Is there a way to get the recent plug-in if my Application Manager is blank and does not show anything from history?
Kevin
Kevin was able to resolve this issue by installing “Autodesk BIM 360 add-in app for Autodesk Revit 2015 R2 Update”.
