Hello Daniel,
In order to troubleshoot this issue I would like to get your model file with custom shared parameters that you are trying to Glue.
Thank you and I look forward to your reply!
Best regards,
Thank you for your inquiry in this forum.
There are some inherent limitations with converting Revit to .dwf or .dwfx format which is how Glue is converting a view from Revit. Our product team is aware of this and are working on improving the process of converting Revit views into Glue.
In the meantime, what we can suggest in order to ensure that the parameters from Revit can be viewed and used in Glue ,is to export the Revit file in .nwc format and then upload the files in Glue Desktop using the drag and drop feature or the Browse feature.
I hope you find this information helpful.
Sincerely,
Frederick
