Created a new project in the Admin area. Invited team members. Can't see new project on 360 Glue desktop. Can only see "Sample Project". Any ideas?
Solved by frederick.regala. Go to Solution.
Hi Steven,
Thank you for posting in this forum.
May I ask who cannot see the newly created project? If it is you, I am assuming that you are the Host Admin, in which case you will also need to add yourself to the project if you want to see the newly created project in Glue Desktop and Glue mobile.
Once you have added yourself into the project through the Admin Console, all you have to do in Glue Desktop is to reselect the name of the Host located on the top portion of the screen. It should refresh the list of projects.
I hope you find this information helpful.
Frederick
You are very welcome!
