BIM 360 Glue Forum
Welcome to Autodesk’s BIM 360 Glue Forums. Share your knowledge, ask questions, and explore popular BIM 360 Glue topics.
CADworx Model Shows As Wireframe
12 REPLIES 12
Message 1 of 13
ghyde
1536 Views, 12 Replies
We have modelled our pipework using CADWorx (for specific reasons).
When the model is brough into Glue, only the pipe centerlines and fitting wire outlines are visible.
Does anyone know why?....and how to show as solids.
12 REPLIES 12
Message 2 of 13
anil_mistry
in reply to: ghyde
Hello Graham,
We are in the process of installing the Object Enabler for CADWorx in the BIM 360 Glue application. We will provide you an update as soon as one is available.
Please, let me know if this help.
Thank you and have a great day!
Best regards,
Anil Mistry
Technical Support Specialist
Message 3 of 13
ghyde
in reply to: anil_mistry
Anil,
In response to your reply, I am assuming BIM 360 doesn't have support for CADWorx objects.
Also, how long does the installation process take - hours, day or weeks?
Regards
Graham Hyde | VDC Manager
Aecon Construction Group Inc.
401 Salter Street
New Westminster, BC V3M 5Y1
T 604-777-5920 | F 604-777-5945
C 604-754-1466 | www.aecon.com
P Please consider the environment before printing this e-mail
[cid:image001.jpg@01CFB1D2.18ECE2E0]
Message 4 of 13
frederick.regala
in reply to: ghyde
Hi Graham,
As a follow up to your inquiry about CADWorx, with it being a third-party application it has to go through several process.
Our product team is currently addressing it, and as soon as we receive any new updates, we will post it here.  In the meantime, would it be possible to send me a sample file for review?  Typically, if it is an issue with the OE, the objects will not be visible, so perhaps there is a display setting that has been overidden. It may be worth checking to eliminate it as the possible cause of the wireframe display.
You may send a sample as an attachment to this posting.
Thank you!
Frederick Regala
Deployment Specialist - ELearning Content Creator
Autodesk Construction Solutions
Message 5 of 13
ghyde
in reply to: ghyde
Sent: Monday, August 18, 2014 7:20 AM
To: 'autodesk.prod|54a00ef4|0eee863e-7990-46a5-8abf-22bda8613fe5@reply01.lithium.com'
Subject: Re: CADworx Model Shows As Wireframe
Graham Hyde asked me to send you a sample file for your review for the wireframe display issue for BIM 360 Glue.
Regards
Richard Clark | Drafting | QC Coordinator
[cid:image001.jpg@01CFBAB2.8E442790]
Contracting
7335 Flint Road SE, Calgary AB T2H 1O3
T 403-571-2121 Ext.2102 | C 403-803-4934
Email rclark@lockerbiehole.com
www.lockerbiehole.com
Message 6 of 13
Hi Frederick,
Any development  surrounding OE for Cadworx, I know the post as 3 years yet, put there must be a  certain demand on that case, since there is always an issue for 3d object files not showing when converting in most Autodesk viewers, like Naviswork and BIM 360 GLUE.
Your help is always appriciated.
Best Regards.
Martin Findlay
Senior piping designer
Message 7 of 13
ghyde
in reply to: mfindlay6B5FD
Martin,
We don't use Glue anymore because it's not flexible enough to handle multiple file formats that we have to deal with.
There's still a long way in its development before I can trust that environment.
For the moment, try saving the DWG file in CADWorx with the view set to Shaded with Edges then NWCOUT. Use the NWC file in Glue. That should resolve the problem.
We also have a problem with NavisWorks/CADWorx 2016/2017 and this the workaround that works.
Hope that helps.
Cheers
Graham
Message 8 of 13
HI Martin,
I have done some quick research on this and it seems that weeks after the original posting, we did install the OE for CADWorx in Glue back in 2015.
I am not certain whether our team did the same for 2016 since we did not receive any support cases specifically for this format in 2016.  May I know which version of CadWorx you are using?  Will it be possible to send a sample file we can use for testing?  You can send it to me directly at frederick.regala@autodesk.com.
We are preparing to update Glue to use the 2018 viewer of Navisworks.  We will test and make sure that the latest OE gets installed after our teams review current or applicable licensing agreements for CADWorx.
In the meantime, the workflow suggested by Graham will work.
Frederick
Frederick Regala
Tags (1)
Message 9 of 13
Hi Frederick,
Message is sent to your email with a test file from Cadworx 2016.
Thanks for your support.
Martin
Message 10 of 13
Hi Martin,
Thank you for sending the sample file.  I received it and I have submitted it to our Glue Dev team to make sure that the OE for CADWorx is included after we update the viewer.  The viewer is actually scheduled to be updated withing the next few days.
Since CADWorx is not an Autodesk product, the licensing agreement will need to be reviewed first before we can install the OE.   This may take a few more days or weeks before it can be added.  We just want to set the right expectations and being transparent with the process.
Stay tuned for updates here or you are always welcome to remind me once in a while :-).
Frederick
Frederick Regala
Message 11 of 13
Hi Frederick,
Any development regarding Cadworx Object Enabler for BIM GLUE 360 ?
Thanks.
Message 12 of 13
I have the same issue when I try to glue the cadworx file from AutoCad to BIM 360 Glue.  any solution?
Message 13 of 13
Hi
Have you got any solution on this issue?
