Aloha, I am trying to align models. watched tutorial https://www.youtube.com/watch?v=pPiAn303USs method does not work. also watched https://www.youtube.com/watch?v=6prBqk_97io&list=PL71F6A665981BE491&index=18 tutorial, statments were made that there are several other methods that can be used to align models in glue. is there other tutorials showing the different methods?
Hello Robert,
Thank you for participating in our community!
Here is a link to a more recent video that shows how to align models in Glue:
https://www.youtube.com/watch?v=N6mY6IAIoT8&index=12&list=PL71F6A665981BE491
If you need additional assistance please submit a support ticket at bim360glue.support@autodesk.com and one of our support specialists will guide you further.
Thank you and have a great day!
Best regards,
Aloha Anil, instructions per link does not work, much mahalos for the advice, will contact support.
Aloha , please see attachment transform coordinates are the same, but models are no where near alignment. Am I missing a step?
Hi Robert,
Thank you for posting in this forum.
To ensure that models line up in Glue when merging different models, the project team will need to determine beforehand which coordinates or base point will be used. Glue will read either Project Internal or Shared Coordinates. It cannot be mixed and matched. You or whoever are responsible for managing the models need to make sure that everyone who are uploading is using the same coordinate system.
How the models line up when inserting it as linked files in Revit or as XREF in AutoCAD without manually adjusting its alignments in either Revit or AutoCAD is how it will also line up in Glue.
If the models in your project have the same base point or reference point, then what you will need to use when Gluing is Project Internal if gluing views from Revit. If there is a published Shared Coordinates then it will be Shared Coordinate. The default setting when gluing a Revit view is Shared Coordinates, the user uploading will need to make sure that the correct coordinate system is selected when gluing views from Revit.
I hope you find this information helpful. If you need additional assistance we will be more than happy to review the models with you. You may submit a support ticket at bim360glue.support@autodesk.com.
Sincerely,
Frederick
