As of right now I don't see any way to select/edit multiple issues besides clicking on each individual issue. Does BIM 360 not have a select all button/functionality.
I have over 1,000 issues to batch edit & I really don't intend on clicking on every single issue individually, I need a select all button. '
Sergio
Solved by a.schear. Go to Solution.
Filter the issues you want to revise. Select the first of the bunch, hold the shift key and select the last item. Select away from the checkmark near the description. They should all select.
This is helpful, but not sufficient.
There should be a single click toggle in order to select ALL issues shown on the page.
Users should not have to hold shift, scroll, click, scroll, click, scroll, click... etc.
Another issue is that even while holding shift, if you scroll too far the system "forgets" (for lack of a better word) that you mean to select all between the two issues and you must start over.
It would be great to know if Autodesk plans to implement a "select all" toggle.
This simple piece of functionality would vastly improve the experience.
It is especially important when browsing large amount of issues, and even more so when you are implementing custom fields...
Since functionality still does not exist in "REPORTS" to actually filter by custom fields (see this post: http://forums.autodesk.com/t5/bim-360-field/filter-reports-using-custom-properties/m-p/5614219#M379), filtering, selecting, and printing all issues with a specific custom field is one of the best work-arounds (though you lose the ability to include your pins)
