I know we can go to equipement and add an attachment to it, but is it possible to have the same functionality with a location.
For example am I able to go to a location and add an attachment?
I would like to have a location set, and be able to associate attachments, issues and checklists to it. I know I can do the issues through the location hierarchy by changing top level to the location.
Solved by chirag.modi. Go to Solution.
You can link document(s) to the location(s) and then create an Issue. There are options where you can "link" the locations depending on what it is you're trying to do. However, it is not possible to go under the locations and then "attach" anythign to them. But, as mentioned, you can go under the Library - documents and link the document to the location.
If you have any further questions, please feel free to send an email to our support at bim360field.support@autodesk.com
You mentioned that we can go to library and then link locations? Would that be done through an APP or Web?
I am currently linking drawings to locations under issues->pins. Am I doing this correctly?
Linking the locations from the web prior to creating Issues using push pins will be more efficient. On the web from the project library, you will be able to mass link the locations which will make the process of creating Issues on the iPad very quick. Please see below on how this can be done:
Documents may be linked to locations both for general reference and for creating push pins. Documents can be linked to a specific location(s) from the project library or by selecting the Issues button located in the homepage of BIM 360 Field.
Linking a document to one or more locations from the project library:
Linking a document to a specific location from the Issues button:
Thank you for the answer. That helps a lot!
I have another question, sometimes I accidently select the wrong drawing while linking it to the locations. How do I remove this drawing from that location?
Thank you once again for all of the help.
Maryia,
Yes, the documents can be unlinked from all locations or from a specific location without deleting the document itself from the project library. Once a document is unlinked, any document reference will also be removed. Issues created as push pins will no longer have a pin reference.
Removing a document from all locations to which it is linked:
Removing a document from a specific location to which it is linked:
I hope this helps.
