When you have multiple projects in BIM360 Field if want reports you have to manually re-create them in each job / project ..... there aren't that many reports that cross project lines? Anyone else run into that same issue / problem? Find have a better solution than just manually re-creating?
Hello David,
Would you be able to provide specific detail that you are trying to generate in this report?
Thank you and I look forward to your reply!
Best regards,
