BIM 360 Field Forum
Welcome to Autodesk’s BIM 360 Field Forums. Share your knowledge, ask questions, and explore popular BIM 360 Field topics.
Enterprise Reporting
1 REPLY 1
226 Views, 1 Reply
When you have multiple projects in BIM360 Field if want reports you have to manually re-create them in each job / project ..... there aren't that many reports that cross project lines?  Anyone else run into that same issue / problem?  Find have a better solution than just manually re-creating?
1 REPLY 1
anil_mistry
Hello David,
Would you be able to provide specific detail that you are trying to generate in this report?
Thank you and I look forward to your reply!
Best regards,
Anil Mistry
Technical Support Specialist
