Can two people work on one daily update?
Will the daily updates be added to the I-pad, similar to the PC?
Additional question:
Status – Can we edit these?
Solved by chirag.modi. Go to Solution.
Maryia,
Currently, only the author will be able to see their own/created Daily Updates. Two people should not work on the same Daily Update (this is only possible if multiple users are logged under the same user) at the same time as the 2nd user will override the previous changes. If two people do need to work on the same Daily Update then one should complete the work, save and then have the 2nd user make additional changes.
The author (author login) should be able to make edits. The Daily Update will be available on the iPad in one of our future releases. ETA is not available on that at this time.
Is there a timeline of when the Daily Updates can be synced and viewed by all Users? This would be a great feature as it is common to have the Field staff input the Daily Updates from the jobsite (often out of town) while the Office staff are in the office. We are constantly sending the PDF Daily Updates back and forth and with all of the syncing 360 Field does already, I'm surprised this part of the program is not able to do the same. Excellent program though, I'm a huge supporter!
Mike
