It would be nice if the library would sort the document names by alphabetic/nummeric order.
We have documents with names like C-18-11345-D1 - C-18-11345-D51. The library sorts the files similar to this . . .C-18-11345-D1, C-18-11345-D10, C-18-11345-D11, C-18-11345-D12. . . etc. Then C-18-11345-D2, C-18-11345-D20, C-18-11345-D21 . . . .etc. So you can see the drawings are out of order. I would like to see this fixed.
Hello Tim,
Thank you for participating in our community forms.
I understand the problem you're running into with the document sorting, but currently this is the format that has been setup in place to sort by. Please send your request into our Idea Station at http://forums.autodesk.com/t5/BIM-360-IdeaStation/idb-p/2032 as this may become available in one of our future releases.
